possible to run one head bolt with all the rest ARP studs?
After doing a head gasket and valve spring swap i cant get the passenger side head on with the bottom head stud in on the left. The stud is to long and it hits the inner fender so i cant get it in, ive tried puttin the head on with the stud at the same time, but still wont work. I also tired putting the stud in first then the head but the headers get in the way then. Its just that one stud one the bottom left passenger side that i want to swap with a bolt instead of a stud.
Is it possile to run one ARP head bolt and the rest all ARP head studs?? or is that a bad idea?
