MS3 going in, any tuning tips?
Hey guys, MS3 almost done in the vette. Im usung EFI LIVE. Anyone have any files with this cam they can send me to look at? Any tip would also be great. I have a wideband comming in the mail. THX
Good luck with your tuning. I have efi live and i am still chasing down lots of problems. It can be a pain so i strongly suggest you install your wideband as soon as you get it. Unfortunately i havent been able to take my own advice so far and i kick myself everyday. This is great tuning software but unfortunately when it comes to availability of tunes EFIlive falls short. I have yet to find a tune that would be decent for my setup
Killaz, I'm about to be in the same boat as you . From my previous F14 tuning experience, Riddlerls1 is right, I won't attempt to tune without a WB, its just too much of a PITA.
Good luck,
Kevin
Good luck,
Kevin
I have the same cam in my z06 and love it. I would not even try to tune it without the wb. If its your first time it will just take some time but in the end you will enjoy the way the car runs. I have stock idle and the car still drives the same just has more power, and my gas mileage went up also. Good luck.
Sorry for the redundancy but i am about to buy a MS3 and would need some help. Is it possiable to see your ms3 file too if yo dont mind. thank you much.
ohenry_28311@hotmail.com
glad to hear!
i think its a bit much for my car because i get a bit of cruse controll but it aint bad
BTW ls1poweredz28 do you mind sending me a copy of your tune when you finish ?? im paticularly intrested in your cold idle portion being mine is still a bit rough
Originally Posted by LS1PoweredZ28
FYI, I just swapped my throttle cracker table for Jpr5690's MS3 table and it worked like a charm...
Kevin
Kevin
My rpm's swing to low @ approx 25 mph after quick blip of the throttle. In others words say 25% throttle to 20-25 mph, off the gas pedal quick, the rpm's will drop low then swing back up where they should be.
Thanks in advance!
