smoke from oil cap?
smoke from oil cap?
I dont know if this is bad or normal, but I installed a breather a week ago and it has smoke coming out of it with engine running, not staining my hood very much but it intensifies with rpm, why/
am I in for trouble?
Are you running a PCV as well? If you are running a PCV as well, this is indicative of excess blowby, if you are NOT running a PCV and just traight breathers, its normal, its just an avg. amount of blowby, all cars have it.
LS1TECH & Trucks Sponsor
NO, you will suck air through the motor, it will go in the breather and out the PCV into the intake. If you are blowing smoke OUT the breather then you have more blowby than the PCV can handle. I took a look at mine today, (breather in one, PCV in the other) and saw no smoke, nor is the breather medium oily or the hood/strut brace directly above it.
what kind of breather are you runnin??? i got a edelbrock or some brand name that is metal on top and on the bottom has holes, with a filter inside of it. got it from autozone and thinkin about buyin one from PFYC.com or speed inc.
