Generation IV Internal Engine - Injectors for 402?
I am building a conservative 402 and will be using LS6/Shaner intake for now.
Any chance I can run it with SVO 30s?
Thanks,
Bruce
Snapps
06-05-2006, 12:36 PM
Thanks,
Bruce
I am running the svo 30s and I have a 408. But I am N/A no bottle no blower. I am at 85% duty cycle.
Jeff
speedracer5532
06-05-2006, 07:40 PM
I am running SVO 42s with about a 65% duty cycle.
Sounds likely
Thank you,
Bruce
KRAZY K 2000 TA
06-06-2006, 09:14 PM
just ran my scan log and i am 85%duty cycle at 6346rpm's wit 42#LUCAS/DELPHI's from racetronixs :)
Blown04Z06
06-06-2006, 10:34 PM
isnt 85% pushing the injectors? wouldnt you want the duty cycle to be a little lower than that?
malibu9in
06-06-2006, 10:37 PM
Jeff
you dyno your ride yet?
Snapps
06-08-2006, 12:37 PM
Yeah with a partial tune and mustang dyno I did 499.rwhp & 468rwtrq af was 12.3 to 12.6 whole time with hooker LT's and I was running cat's. I would like to dyno it once more now. Added pace setter LT's, ORY, & retuned. :)
koolrayz
06-11-2006, 08:35 AM
Im seeing 80% on motor. I have the SVO 42# I wouldnt risk running a 408 on 30# injectors
Snapps
06-12-2006, 11:03 AM
whats the risk.. Koolrayz? If he is not spraying or supercharged then where is the risk?
PPl run stock injectors duty cycle up to 120% which is a risk...
I am going to try the SVO30s and see if I can do it <85%. If not I will jump up to 36 or 42# SVOs. Not wild about duty cycle above that because at track days I run prolonged periods at fairly high RPM. I was < 80 with old motor but expect, or even hope, I will need need more fuel with stroker.
Thanks,
Bruce
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
