how hard is it to install PHR??
Install is easy...comes with instructions, you can also view/download them from BMRs website. Measure the stock bar bolt holes center to center, then transfer that measurement to the new one to start - adjust from there if needed. Get a helper, you may need to push in on the tire/wheel to get the second bolt through if the rear moves.
