Which rockers does everyone prefer??
I think most people will agree that, the harland sharp rebuilt stock rockers are a very good option. I have a set that I am just got done, but unfortunately will not be able to use, let me know if your interested.
The nasty's are the harland sharp rebuilds. Nasty Nate sends them out to HS.
I heard the aftermarket harland sharps had some valvefloat issues, atleast the old ones did, i think theyve since ben revised. Not too sure about the yellow terras. Another choice is the comp or even the crane rockers.
The HS rebuilt stockers are the way to go. They are light are durable. Unless you go solid roller and need an adjustable rocker, I don't see a reason to stray from the oem gear.
Harland Sharp rebuilds are a good choice.
Stock huh? That way when you get a big cam and spin your engine to 6500 it will dump needle bearings everywhere.....And didnt the question ask which do you prefer between Yellow Terras and Harland Sharpe?
Originally Posted by KOTSperformance
stocks...............
