Conversions & Hybrids - is return fuel line needed, can regulator be placed next to tank?
shanekennedy
06-06-2006, 07:11 AM
going to run a in-tank pump
is there any reason the fuel-pressure regulator can't be placed next to the tank, or does it need to be near the engine for some reason?
Stu Cool
06-06-2006, 08:28 AM
Mine is right next to my tank, return line is about 15 inches long.
Pat
stealth71
06-06-2006, 09:05 AM
If you use the corvette filter w/ the built in requlator they are usually close to the tank from the factory. I assume you could run any regulator like this.
Oscar Will
06-06-2006, 09:09 AM
Mine is the Corvette part, right next to the tank also. I don't see why you couldn't run any other regulator the same....as long as it's a bypass type.
The Red Baron
06-06-2006, 10:22 AM
If your fuel feed line is small and requires the higher pressure to keep up with demand the regulator should be closer to the motor. ;)
