ATI Cooling Improvement (Pics)
Old 06-06-2006, 09:14 AM
Cyborg's Avatar
Default ATI Cooling Improvement (Pics)
I did the dlandsvZ28 mod. If you have to run the ATI shroud for clearance reasons, this is one way to improve things (before & after pics):
Attached Thumbnails ATI Cooling Improvement (Pics)-shroud-before1.jpg   ATI Cooling Improvement (Pics)-shroud-after1.jpg
Old 06-06-2006, 10:46 AM
TS6
TS6's Avatar
Do you just wire the smaller fan into the same wires as the larger fan?
Old 06-06-2006, 10:51 AM
Flossin' twin turbos
Moparnos (The SLP Guy)'s Avatar
thats neat, did it make a difference in the temp though
Old 06-06-2006, 01:37 PM
TECH Cry Baby BOSS APPROVED!
Urban Legend's Avatar
Did it help or not? I have a 9 inch Spal going in tomorrow, so I am interested.
Old 06-06-2006, 01:39 PM
TrakDay's Avatar
I din't know other ATI shrouds only housed one fan... hmmm. On my GTO kit I have a larger and a smaller fan just like what you modded yours to look like. Either way I bet thats a huge improvement!
Old 06-06-2006, 02:09 PM
Bad30th's Avatar
What's the P/N# for the fan you used and where did you get it ? (PM me if it's not a site sponsor...)
I've been thinking about doing this for a while, and with hot summer days coming up again soon...
I already swapped to a SLP (LT1) radiator and removed the A/C stuff so it should run cooler, but I bet that 9" fan helps a lot with that "dead" side of the radiator the ATI shroud blocks.
No fitment issues with the blower/inlet hat, right ?
Rob (Bad30th)
Old 06-06-2006, 02:33 PM
DJ's Z's Avatar
This is what I've done...uses some of the best fans available...should keep my temps down just fine along with the SLP (LT1) radiator...
http://www.sd-concepts.com/cart/inde...c581143dfea417
Old 06-06-2006, 06:20 PM
Cyborg's Avatar
It wires right in to the stock wires for the stock duals.
Old 06-06-2006, 06:33 PM
Cyborg's Avatar
Yes. Before I really couldn't use the a/c. The big improvement I saw is now I'm able to run my a/c w/out overheating, unless it's stop & go traffic on a real hot day. Last Thursday it was in the low/mid 80's and I drove 55 miles on the highway to Boston with the a/c on full blast and the temps running 198-202. Now when I got into the city and hit stop & go traffic over the course of 15-20 minutes the temp crept up to 220 and I had to shut off the a/c, and the temp came back down. But it seems like now I can run the a/c as long as the car is moving at least 40mph or so. On a cooler night however (70's), I was actually able to idle my car for 20 minutes w/ the a/c on full blast and the temp went to 214 and held. So it's not perfect, but it's a heck of a lot better than not being able to run the a/c at all because my car is a daily driver.
Old 06-06-2006, 06:44 PM
Cyborg's Avatar
Rob (Bad30th)
I opted for the lowest profile 9" Spal because I was worried about clearance issues. The larger profile pullers may flow more than this one. This one is PN: 30100392. Also I have the straight blade, and I think the curved blade (30100452) puller may also flow a little more. No fitment issues for me with that fan, but don't go by that, because I have a very customized setup and clearance will be a little different for everyone...but if anything is gonna fit, I think it will be that low profile 9". Good luck!
Old 06-06-2006, 06:48 PM
Cyborg's Avatar
You're definitely gonna flow some serious air!
Old 06-07-2006, 05:52 AM
Bankz27's Avatar
Looks really good.....I hope it works out well
Old 06-07-2006, 07:59 AM
MiaSSmaro98's Avatar
im going turbo soon and i was gonna cut out half of my fan shroud out for space and modify the other half to go on front.
Old 06-07-2006, 08:12 AM
Scary Guy's Avatar
[QUOTE=Cyborg]Yes. Before I really couldn't use the a/c. The big improvement I saw is now I'm able to run my a/c w/out overheating, unless it's stop & go traffic on a real hot day. QUOTE]
Would it be worth it if i don't have a/c?
Old 06-07-2006, 11:34 AM
Cyborg's Avatar
[QUOTE=Scary Guy]
If you are running warmer than you want to be, and if you've already put in a 160 stat and adjusted when your fan comes on, then I would say it is definitely worth it. The fan is $80 or so and a metal shop cut my shroud for $35 so it's pretty cheap insurance if your running warm now, drive in hot climates, or in traffic.
Old 06-07-2006, 12:27 PM
Scary Guy's Avatar
[QUOTE=Cyborg]
The car is not my everyday driver so i shouldn't have that problem.Thanks for the reply!!!
Mark
Old 06-07-2006, 12:32 PM
Ferocity02's Avatar
Isn't there a set of dual 11" Spal pushers that fit on the front of the radiator? Might be a different brand but I remember that there is a set that fits perfectly in front with little to no modification.
Old 06-07-2006, 01:24 PM
Cyborg's Avatar
There might be, but you'd still want to cut a hole in the shroud on the back side IMHO...blocking off half the radiator like the unmodified ATI shroud does really hurts IMO.
Old 06-07-2006, 10:04 PM
Rob (Bad30th)
I found out today that if you are running the SDCE tensioner and try to run the Spal 9 inch high performance puller fan (30102061) it will not fit. The fan motor hits the top bolt on the SDCE tensioner. The fan is too thick @ 3.7 inches. So now I have the fan listed for sale.
https://ls1tech.com/forums/lsx-parts-sale/521569-spal-9-inch-high-performance-fan.html
Old 06-08-2006, 12:18 AM
WS6 #3392's Avatar
This is my only concern when I do my ATI Procharger. I want to keep my ac but hate having to worry about it over heating if I do.
Quick Reply: ATI Cooling Improvement (Pics)
