runs badly when cold, but good when warm
Cold-crap! Warm-good?
Ok, here is my problem when my car is cold it runs like crap almost like it is
missing until it warms up, Then it cleans it self out and runs great until I turn it
off for a couple minutes and go drive some more and it has to clean it self out again . What could cause this to happen and what are some things can I check on to make it run better....any suggestions
I called some of my friends the only that could get a Bazooka was cylde he is going to show up tomarrow morn with it, The only bad thing is he is a midget and those are big guns, Im thinking I will sit in the driver seat while he shoots it so I can get the full effect, eh. I have a helmet I think I'll wear to it has flames
the LS1's do run richer when the motor is cold. This may be what you are experiencing. The motors are more torquey down low, but also seem more hesitant when they are running cold.
Tech Resident
Originally Posted by 2K2WS6TA
In the old days it would be the choke that would cause that, so what on an LS1 serves the same function??????
i'd say his injectors are clogged. engines need more fuel when they are colder because they RPM higher. if his injectors are clogged, it'll act like it's missing when it's cold and once it's hot and it requires less fuel, it'll lean out a tad.
run a 5 dollar can of seafoam through your gas tank, see if that fixes it. i'm serious, even if it doesn't fix the problem, you'll probably pick up an extra 1 mpg.
Tech Resident
Originally Posted by MasnarT
Thanks For All The Info Guys, I'll Try The Seafoam Tomarrow
1 Post
Originally Posted by Shinerbock07
what hapened to my post about midgets+bazookas=emergency room? Was it deleted or is my computer messed up?? Oh well...
Well I put the seafoam in m tank and it sure fixed the problem it runs alot better
I guess maybe it was a sticky injector , runs good now --thanks for the help
