LE3 Head / LE3 Cam People
http://www.eportworks.com/
why dont you just call Lloyd and talk to him about your plans/setup for the car and he will be able to tell you i would guess.
I'm not changing heads. According to the flow numbers Lloyd gave me for my AFR's he ported compared to LE3 setups my heads flow more. It's just the closest comparison I could use to get the info I need to decide on what stall.
Why doesnt someboady also just post a dyno sheet, or give him the information that he is asking. Maybe other people might want to see what the LE3/LE3 stuff does?
https://ls1tech.com/forums/showthrea...&highlight=LE3
I have ported afr 190's from Lloyd and a LE3 cam 355". I peaked at 6600 just like looyd and Bret had told me it would. It put down 400 through a th400, 4000 verter, 12bolt (4.10) gears, steel shaft. etc,etc. It is hard to say on torwue because it is avery flat curve, but I can tell on the street around 5000rpm it pulls very hard. My converter flashes to around 4200 off the bottle, but even if I goose it to 3000 it lights the tires up until I let off.
chris
chris
We have the exact same heads ported to the same specs. Your cam is biger than mine though. This was the type of info I was looking for and the reason I made this thread. Thanks for chiming in.
11.20's IMHO
