Long post, Quick ?, HP vs. Torque
I noticed on most dynos the peak torque is higher than the peak hp. I know this is especially true with n2o. When my car was dynoed, could only squeeze 2 untuned pulls this day, my hp and torque were almost identical. Basically i wanna know what determines for the hp to be more, the same, or less than the torque output? This comes down to me not totally understanding the difference between the 2, i've heard the saying " horsepower sells cars and torque wins races" but dont totally understand that either,lol. Thanks for any help
Old Drag Racer
Originally Posted by 11SECDWS6
cars with a unlocked high stall will do that too---high torque, low hp
Originally Posted by PewterZ28
I would have to totally disagree with that based on my experience and a few others I have seen on this board.
409rwhp/493rwtq
as referenced in thread: https://ls1tech.com/forums/dynamometer-results-comparisons/521354-stalled-th400-low-compression-n-402-results.html
And this: 464rwhp/504rwtq
As referenced in thread: https://ls1tech.com/forums/dynamometer-results-comparisons/475800-408-et-245-heads-dyno-numbers.html
Just for starters….
8 Sec Tuner
Torque and Horsepower are related to each other by RPM. HP = (TQ x RPM) / 5252. That is why at 5,252 RPM HP = TQ.
Torque is a generally a function of cubic inches. You can build a 427 LS1 with stock heads and it will still make around 510 Ft. Lbs. of torque, it will just be down big time on HP, so it will be slow.
