13.5 @105 can some one break this down for me (where i need to improve)
60ft 2.173
330ft 5.908
1/8 8.903
mph 82.73
1000ft 11.422
1/4 13.569
mph 105.9
launch at aprox 2k some axle hop going on, shifting in to 2nd it spun for a lil bit, shift light was set at 5900 and i was shifting when it came on, i think i could shift a lil faster any tips)
im geting alot of cars in my area that are geting faster but im not (yet) and i would like to know if its got more in it
the runs where made w/o the long tubes
i have a video of it here
http://videos.streetfire.net/video/E...2C04D2B851.htm
330ft 5.908
1/8 8.903
mph 82.73
1000ft 11.422
1/4 13.569
mph 105.9
You need to start with your 60'
By the looks of the video... you might have left at 2k, but it looks like you just about dumped the clutch and then floored it. You have a stout clutch which can take more abuse than that. Try leaving at even 3k and slip the clutch a little and be smoother on the throttle and you'll leave harder with less wheel spin. Dropping the clutch like that might work on slicks and a strong rear... but you'll need to modulate your clutch & gas more to get a better 60'. What do you have for tires?
Yeah 2500 or 3 like Naut said. but feather the clutch and get the rolling start then hammer on it. check my profile for run times. i did a 13.8 with 330rwhp at 104ish i was like wtf. So I went out and got LCA's and 18's with Z rated tires instead of H rated 16's. Did that feather of clutch and dropped 1/8 mile time from 9.06 to 8.62. No new times on the current setup. hope that helps
Originally Posted by prostock_bigblock
Even with that 60` and your mod list you must be in the 12`s.
Trap speed looks very low to me to.
Originally Posted by alsfastz28
60 ft needs iinprovement lower air in tires limp it out dont dump clutch and shash it to floor
With this already being said lets go from there.
Get a torque arm and sfc's along with a pan hard rod bar and the enjoy 12.6's.
You need suspension work. After modding several f-body's I have come to realise most of them are usless without Suspension work. Put that power to the ground and lose less P thrue the bending of you stock parts.
Need to practice leaving, thats where its all at. I spent many days racing, and have seen 5 tenths from just learning how to drive a stick car to max potential. I used to leave at 3200-4000 on street tires (Eagle F1s, ridgestone Potenzas) and cut 1.81-1.93 60 fts. Lots of clutch modulation going on
Get a good tire and it will help, along with the basic suspension pieces. Wheel hop alot of times is incorrect LCA angle, driving style, or beat bushings in control arms and such
hey granny its justin (9" install soon)
ive tried different launches but none seam to work for me.
and i dident want to use a D/R on the stock rear.
so im buying a 9" with 4.11s with a set of d/rs and i wont have a problem.
i might give teh track another shot be for the new rear thoe
