'99-2002 truck TB same as LS1 TB for F-body?
Old 03-08-2003, 12:22 AM
BADSZ28's Avatar
Default '99-2002 truck TB same as LS1 TB for F-body?
Are they the same? What is the difference?
Any feedback would be appreciated,
Thanks.
<small>[ March 08, 2003, 12:23 AM: Message edited by: Bads02Z28 ]</small>
Old 03-08-2003, 09:13 PM
BADSZ28's Avatar
Default Re: '99-2002 truck TB same as LS1 TB for F-body?
Thanks a lot guys. I will play it safe and get a ported stocker.
Thamks.
Brent
Old 03-09-2003, 12:30 AM
Wicked ls 1's Avatar
They are different in two ways larger=good but there calibrated for the truck so it may run rough =not good, slp sells the recalibrated truck maf for $150.00
Old 03-09-2003, 12:42 AM
SStrokerAce's Avatar
Hey,
The Truck TB is not the same as the F-body one, but VERY similar. It's close to the 98-99 F-body TB, the cam is slightly different and the return spring is orange. You also have to run the coolant bypass when you do it because the line are in the wrong place.
Bret
Old 03-14-2003, 05:42 PM
REM
REM's Avatar
Mark Shaner made my S2 out of a truck TB and I have no problems. I picked up 10 RWHP and told him no when he asked if I wanted to give him that one back and get an f-body TB instead.
Ryan
