Manual Transmission - Mcleod clutch pedal pressure extremely hard
big dave
06-08-2006, 04:14 PM
Is anyone else having this problem? I've adjusted and bled the MC but no change in the pressure need to depress this clutch. Is this normal or do I have a bad MC?
11 Bravo
06-08-2006, 05:29 PM
I ran a McLoed and gained 20 pounds of muscle on my left thigh lol. I had problems speedshifting it was so hard to push. Running a Spec 3 now and it's so much easier.
Dal1as
06-09-2006, 01:05 PM
Is it the single disk kevlar? Mine is a bit stiffer than stock but nothing like you're explaining. Did you replace everything (throwout bearing, etc.)
pewter 01 SS
06-09-2006, 01:25 PM
I also have a twin disk and yes mcleod clutches are a lot hard.. and like 11bravo said you will see an increse in muscle with your left thigh hahah lol.. unless its really extremely hard and it might be your slave cylinder.. did you change your master cylinder already? if you havent you should try changing both.. it will help..
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
