all you sts guys...how much do you have in your setup
Old 06-08-2006, 04:56 PM
thislswon's Avatar
Default all you sts guys...how much do you have in your setup
just as it says above,....anyone on here with an sts kit,....just curious on how much you have in your setup...some ppl say 10k isnt enought with change left over to do an sts setup
Old 06-08-2006, 07:05 PM
2002/Black/SS's Avatar
10 grand not enough for an sts? thast sounds just a tad off, by like 5000 bucks
Old 06-08-2006, 07:18 PM
JAvenger007's Avatar
the word STS
theres plenty. And i agree, $5K is a good setup. check out trtturbo.com for their packages. i believe their full upgraded turbo packages are complete for under $7500 out the door.
Old 06-08-2006, 08:17 PM
LastBlack02SS's Avatar
I suppose it really depends on what supporting mods you do. My tranny was dying so tack on that as a cost, i did LS6 cam swap, heads, valvtrain, etc. Also depends on the tune and tuner. Use the search function, but also as said above, look at trt and that should give you a good idea.
Old 06-08-2006, 08:30 PM
LS1Tech Sponsor
Superman09's Avatar
I think you can get into a really nice kit with some nice goodies and a cam for about 6k. Then install yourself, pay for a tune, in for 7k ish. This will limit you to 400-500 rwhp and you may be borrowed time on your rear depending how you drive
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old 06-08-2006, 08:32 PM
52172's Avatar
Quick answer NOT ENOUGH TO KEEP UP WITH THE FM's!
Old 06-08-2006, 08:37 PM
mahhddgtp's Avatar
Has anyone else been on trtturbos.com?
Old 06-08-2006, 08:44 PM
Administrator
unit213's Avatar
You said doing it "right"...not just slapping a STS kit on there.
You also said running it at 9psi.
Old 06-08-2006, 09:18 PM
LS1Tech Sponsor
Superman09's Avatar
i think With the complete packages now for the STS with FMICs and tons of other upgrades... the rear mounts will end up cheaper than most log style front mounts and still perform as well as a log set up. The numbers of the Rear Mount STS kits are right up there pushing 500 ish rwhp on 8 psi with m6. For the combo's now available from TRT, i dont think you can beat it
__________________
Old 06-08-2006, 10:17 PM
ok ok so it was a minor typo i fixed it now lol
Old 06-08-2006, 11:39 PM
SSilverSSurfer's Avatar
true but theres a certain rear mount vette looking for 1000+ when hes done
Old 06-09-2006, 06:50 AM
smokinHawk's Avatar
still not more then the 1500+ a few front mounts have done
Old 06-09-2006, 07:17 AM
LS1Tech Sponsor
Superman09's Avatar
i think if your shooting for a high hp race car, no way rear mount should be what your looking for. However, if your looking for a good kit on stock block, or mild setup for forged bottom end, i dont think you can beat an STS's price and performance for that application. Big HP and race car is another story.
__________________
Old 06-09-2006, 09:14 AM
Schantin's Avatar
Got the STS kit for $3.5 (w/injectors & boost gauge and optional GT67 turbo), already had CC918 springs and hardened pushrods from my cam....and still aded enough crap to equal approx $7K. This included in-tank fuel pump and wiring, wideband O2, FMIC, fuel regulator and line upgrades, custom welding if the exhaust, tuning, plugs, + 8 million minor misc things that suck $$.
The car is reliable as hell and put down 426RWHP / 436RWTQ (SAE) at only 5PSI. Still hae more power left as I haven't installed all the fuel system upgrades.
Old 06-09-2006, 09:21 AM
ZL1Killa's Avatar
Schantin, yeh man you got power left in it. buddy of mine was putting down 472HP and 514TQ @ 5psi; he had ported intake 90mm, and 90mm tb...his was a 2001 T/A
Quick Reply: all you sts guys...how much do you have in your setup
