purchase new headlight.
where is the best place to purchace a new regular low beam headlight. i used eletrical meter and their is current going through the contact so the filiment must be done for or whatever.
walmart doesnt carry any at its stores yet is had the type listed......
LS1Tech Administrator
Received 1,467 Likes
Originally Posted by TylerDurden28
Autozone would be my best bet.
Any autoparts chain should have it; Autozone, NAPA, Pep Boys, Murray's, etc.
Going through the contact or to the contact? If you were doing a resistance check, there should be current going through the bulb, giving you a ohms reading. If it were open then it would be bad.
Or, are you talking about the current going up to where the bulb plugs in?
