228/232 on a 110 LSA--Anybody running one??
Just ordered a 228/232 588/592 on 110+1 on XE-R lobes and was curious if anyone was running anything similiar on a 110. I see many running something close to this on a 114 or 112 but never on a 110. The ones that are just wanted to get a little feedback. Power, sound,??
I have an XER 228/232 (.588/.595) 110 +2 sitting at the shop, i'm waiting on my heads to be done to throw it in.
There is a guy on there that spec'd the same cam that made pretty good power cam only though a 12 bolt awhile back.
well he said that many people are running it on a 114 and a 112 so i just wanted to say that i was one of the 112 people. if its on a 110 it will have 2* more overlap and have a slight amount more low end tq. its not going to be that much different to tell you the truth. it will sound a little more lopey also. WTF is your aannnddd **** supposed to mean. not like it is you ******* thread. i was just trying to help him out if he wants to ask me anything about it since i have just about what he is wanting.
Seems like the guy's name was Josh. He had it on a 110 +2. Very nice midrange and low with peak hp coming at about 6300 w/ a shiftpoint about 6500. If I remember correctly this cam didnt really fall off that bad at all after peak hp either. I'll probably go with this cam.
Originally Posted by SUTTERERMAN85
you are right about the 4* not the 2* that is my fault. i was under the impression that the lower the lsa that would have a lower peak rpm. i guess that it might be worng on that too
The 112+4 is a 42 IVC
The 110+1 is a 43 IVC
so the 110+1 will peak later than the 112+4 (by ~ 100 rpm)
Here's a similar cam, that I'm really thinking about running.
https://ls1tech.com/forums/dynamometer-results-comparisons/513122-mtisiir-g1-update.html
Bruce
Bruce
Im running a 228/232 .600 110lsa Idles pretty rough. Its a 6 speed and before I put gears in (4.10's) it seemed like it had no power below 3500 rpm. Im still running the crane powermax tuner but I think it still needs a dyno tune.
Bruce
Your first post implies that you're an imbecile, and this one confirms it.
Originally Posted by Pewterme
I'm all ears, like to hear it.
