It's ALIVEEEEEE!!!One issue
Well guys. The MS3 along with all my other componets are in. Fired the car up and it started right up and ideled at 900. I was soo happy. BUT then i saw there is a little coolant leak in the back of the intake. So after work ill pull the intake and hope its an easy fix. Could only be the little coolant pipes right? Anyhow, there was no valve train noise, and ideled for about 3 min right at 900 RPM's. Man im happy
holla
holla
Originally Posted by killaz
i did not do heads. Is this plug on a set of stock heads? Could i have knocked it out?
yes it is, I doubt you knoccked it out. it is where the water temp sensor goes if you put that head on the driver side.
