Which K-member setup?
I have owned a PA-Racing K-Member (on a 3rd gen) and it was decent qaulity. Jen's Z28 has a BMR unit and that is what I am planning for my 2001 Camaro SS. I hear AJE (or what ever) is also good, and UMI is coming out with one of their own.
Race your car!
Originally Posted by 02SOMWS6
I pa and they forgot to put a tab on oneside for my swaybar and the fitment was terrible, i had to grind hammer and pull and tug.
The swaybar part I could care less about.. as my fron tone will never go back on... but the part about it fitting like crap, that will make me stay way away from that thing.
Either a BMR, or the UMI one once it's released will be my route I think. The umi one is gonna be heavier then the others, but still be a 25 lb savings, and a good amount stronger then the other aftermarket ones I understand, something that can withstand some street use without any major worries... Sounds like a winner to me.
Thank you!
Ryan
Race your car!
Originally Posted by UMI Performance
Yes exactly, our item will be slightly heavier but it is designed to handle street driving and street abuse as well as drag racing. We hope by the end of summer to have this item approved for AutoX/RR as well. We will have some update product pictures up hopefully next week as well as some installation pictures so please keep checking.
Thank you!
Ryan
Thank you!
Ryan
Keep me posted.
LS1Tech Premium Sponsor
Originally Posted by LT1LE
Are You Going To Make A K-member For Us With Third Gen's....please
we offer several different variations to best suite your needs. Let me know if you have any questions....
Lee Spicher
lee@bmrfabrication.com
(813)986-9302
Restricted User
PA Racing CM one here. Fit was great, everything lined up and provides good amount of adjustability. Been street driving it A LOT since install, no issues. I cant see a beefier K Member itself saving 25lbs, maybe a regular CM one, but any beefier and you got to give up a little of that weight savings.
Race your car!
I'm personally o.k. with a little less weight savings, as long as I can save 40+ from swapping the K and the upper and lower a arms, I'm good to go. With the removal of the a/c and a LW battery, I'm already losing over 40 off the nose as it is, I was hopign to get about 100 off of it without removing the bumper support, a LW radiator overflow, and removing the abs completely with an SJM kit will get me there, as long as swapping the K member and all 4 a arms saves me at least 40 lbs.
