D1SC Pulleys -- 8 vs. 12 Rib
Old 06-09-2006, 09:29 AM
Fastbird93's Avatar
Default D1SC Pulleys -- 8 vs. 12 Rib
I know this is for an LT1 but you guys seem pretty freaking knowledgable here. Building a 383 LT1 (Lunati crank/rods, diamond -35cc pistons, fully ported TFS heads, custom cam) and going to throw everything we can at it. I'm already intent on the SCDE Tensioner, but my question is this:
I've heard that there are simply more belt options for an 8 rib pulley vs. a 12 rib pulley. With the SCDE Tensioner would it make more sense to go with the 8 Rib due to the ability to run a wider variety of sizes for more boost control?? I guess it really boils down to will the 8 Rib with SCDE Tensioner hold up without slipping??
Old 06-09-2006, 01:19 PM
conan's Avatar
I have the 8 rid with the scde tensioner, adjusted the tension when I installed the blower and haven't touched it, no belt slipage at all.
Old 06-10-2006, 05:38 AM
EPP
EPP's Avatar
I don't believe that SDCE has a system for the LT1, but I'm not certain. The ATI ProCharger 12 rib pulley system is a good way to go, though. You shouldn't see any belt slippage with this system, it's too bad it can't be offered for the LS1 cars. Bob
Old 06-10-2006, 11:50 AM
Fastbird93's Avatar
Bob, they do, I've personally talked with them about it and it's on their website. Right now I'm sitting on a couple of 12 rib pulleys as that was my original plan (SCDE w/12 rib) but after talking to people and searching around I'm running into a lot of "there's more easily accessable and different sized 8 rib belts than the 12 rib belts." We're trying to do everything we can in terms of pulleying on the new motor and don't want to run into a stopping point based on the fact that I can't get a right sized 12 rib belt.
Quick Reply: D1SC Pulleys -- 8 vs. 12 Rib
