ms3 vs g5x3
Depends on your goals really. Plan on spraying at all? *I believe* the MS3 is larger than the G5X3 so you will probably need a slightly larger stall. TSP also has a new cam out called the MS4, similar specs with a lot more lift. That should make really good power as well.
However, I'll tell you to get the TRex and a 4400 stall and win every race you're in
