Ran a little better at Bristol last night 10.36 at 135.5mph
Old 06-09-2006, 11:23 AM
Coal Mining Director
onfire's Avatar
Default Ran a little better at Bristol last night 10.36 at 135.5mph
Density altitude was 4089ft
Raceweight was 3740 lbs....lost some car weight from last year...almost 100lbs.
60ft 1.77
1/8 6.76
mph 108.93
1/4 10.36
mph 135.51
Ran another 10.40 at 135.x actually qualified for the "Quick 8 Power Hour"
Won first round, gave away the second round on a REDLIGHT ...made the final 4.
New Bell IC dropped the IAT's 40 degrees over the Incon baby's....still too high though as I pushed the baby GT28R's to 16psi....picking up 45 to 50 degrees over ambient by the end of the run...caused my timing to drop to 6 degrees in 3rd gear....
Old 06-09-2006, 11:52 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
What were your IAT's at the end of the runs?
Old 06-09-2006, 12:51 PM
OneMeanZ's Avatar
Very nice runs! Wish I would have showed up to see that bad boy!
Old 06-09-2006, 01:05 PM
onfire's Avatar
95 launch
145 end
keep in mind that was pushing the gt's to 60%eff....probably 280 outlet temps
Old 06-09-2006, 01:13 PM
Project GatTagO's Avatar
Received 1,393 Likes on 879 Posts
Someone needs bigger turbos...
Although I bet they drive very nice.
Andrew
Old 06-09-2006, 01:20 PM
kp
kp's Avatar
Congrats Tom, thats a tough track to run quick at. I ran 134 there last year @ 3200' and thats all it had lol, just keep working on that 60 foot. I forget what my 60's (1.38 or so I think) were there but I ran a bunch of 10.0x passes so you have the power to get in the 9s there if you are running 135.
Old 06-09-2006, 01:27 PM
SSU Moderator
RyanJ's Avatar
So you gonna pick up some -0012 (55lb) turbo's or what?
Old 06-09-2006, 01:32 PM
onfire's Avatar
I'm jonesing for some reallll baddddddd.
I'll save up for them for a winter project. APT makes a nice looking hybrid with the T25 turbine.
The rest of this year is taking kp's advice....I'm leaving way too much on the table with 1.77 60's.
Gotta get this Harlan 2 step to work...leaving off the footbrake with no boost at 2200rpm sucks.
Old 06-09-2006, 01:33 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
What all did you take out weight wise?
Old 06-09-2006, 01:45 PM
SSU Moderator
RyanJ's Avatar
Yeah, that 60's killing you. I would think you could do better even w/o boost, but I guess your car is pretty heavy.
Old 06-09-2006, 02:09 PM
onfire's Avatar
Bogart's and the front IC was worth around 80 lbs. I still have factory brakes, AC, PS, Airbags,Monsoon radio, full exhaust, etc, etc
Old 06-09-2006, 06:47 PM
Mike 01WS6's Avatar
Those are damn good runs at 4,000' DA! Easy 9's on a good track and fair conditions.
I'm impressed.
Old 06-09-2006, 09:45 PM
TS6
TS6's Avatar
What kind of power are you making in race trim? Just curious as my car will be about that heavy...
Old 06-09-2006, 11:46 PM
onfire's Avatar
Thanks for the props guys....lots of wrenching turning finally starting to pay off a little bit. Car dyno's high 600's at 16psi through a t400 trans.
Old 06-11-2006, 06:48 AM
cablebandit's Avatar
Congrats!! I still have no idea about your 2 step acting up.
Old 06-11-2006, 08:41 AM
LS1Tech Co-Founder
Nine Ball's Avatar
Tom, you should have just bought my silver Formula to drag race. Don't gut the Firehawk, its too nice of a car
Old 06-11-2006, 09:38 AM
SScam68's Avatar
Thats awesome Onfire.
No joke there is still A LOT in your car but it's a great show-n-go car. Don't tear it up
Great to read your results with the new IC. I don't plan on installing the smaller units when mine goes on.
So you haven't even used the 2-step yet?
Old 06-11-2006, 10:36 AM
onfire's Avatar
Thanks for the comments guys. This car will never be gutted. I still drive it to work on sunny days. I drove it 1 hour to the dyno. All factory options still work.
Thanks to Harlan, I think I got the 2step working yesterday. It was set too high to allow the tight Vig enough room to flash, causing it to tug boat launch. I haven't used it at the track yet, but it now hits the tires like it should...I still have some PCM fine tuning left to do on the rpm vs PE as it was running 10.1 : 1 af up to 4400 rpm. I'm looking forward to a 4psi launch.... 0psi footbrake launches are lame.
Old 06-11-2006, 11:17 AM
LS1Tech Co-Founder
I dynoed 680rwhp when I went 9.6@144mph back in July 2005. You are probably right there, what with racing at that DA and at that raceweight.
Quick Reply: Ran a little better at Bristol last night 10.36 at 135.5mph
