Old 05-20-2016, 02:01 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Chevrolet Camaro or Pontiac Firebird Lighting Guides
Print Wikipost
Do you have to remove the bumper to replace a Camaro's headlight assembly?
Old 06-09-2006, 12:49 PM
silverta16's Avatar
Default Do you have to Remove Bumper to Replace Headlight Assembly?
My 98 SS has a cracked headlight lens. Do you have to remove the bumper to replace this whole assembly. I'm having the front bumper painted and was wondering if I needed to get a light now, or if I could wait a while. Thanks Brandon.
Old 06-09-2006, 01:07 PM
Shirley Temple Drinker
Sgt. Spuds's Avatar
You could wait, you don't take the bumper off to get to teh headlight assembly, but I'd do it now anyways..
Old 06-09-2006, 04:56 PM
Zymosis's Avatar
You can wait if you want. But it isn't required. Just turn the adjustment screws all the way (so the headlight is furthest in), and take off the 2 10mm bolts (if I remember correctly), and you can slide it out without a problem.
Old 06-09-2006, 05:02 PM
HeapaShifter's Avatar
There is only one 10 mm bolt holding the headlight in. Take that bolt out, and then slide the light to the side, and then jiggle it a bit. It will come out.
I seem to be taking my headlights off every month for various reasons.
Note: You actually have to take the headlights out to remove the front bumper.
Old 06-09-2006, 05:37 PM
Mike02Z's Avatar
I'd replace it before getting the bumper painted as then there is no chance of scratching your newly painted bumper trying to replace the headlight. Mine have been in and out various times and I've never scratched the bumper but why risk it when you need a new one anyway?
Quick Reply: Do you have to remove the bumper to replace a Camaro's headlight assembly?
