7mm valves on solid roller setup???
here's my story. I bought a set of 'super best of the best' used stage 3 GTP solid roller heads from a board member. I send them off with the rest of my goodies to a very reputable builder to have everything put together. Today I get a call that these heads are junk. Instead of 8mm valves these have 7mm and the springs are also walking all over the heads. They also said the welding that was done on them was shakey at best. Now I'm at a loss on what to do. These heads supposedly ran low 9's on the previous owners car. I guess I'm just looking for input on what to do and if anyone has heard of a setup like this before.
Brandon
I don't have any pics. They are at a shop on the other side of the country. I have no idea what welding or why it was done. I do know all the work was hand done by craig at GTP. The shop told me there were no locators(i think) and the springs basically were just sitting on the head.
The combustion chambers had some welding and the spring pockets had some welding done as well. I just went back and sifted through some old emails and pm's and found that info. I know the heads had some work done and were set up specifically for t&d rockers as well.
Wow, who is taking the heads apart and has this opinion of them? I'm pretty doubtfull that they know more about heads than Craig.
DO NOT GET 8mm guides put in them so you can run heavier junk valves. DO NOT GET A NEW VALVE JOB PUT IN THE HEADS EITHER!!!!
Are the 7mm valves in the heads bent?
The areas that are welded are not a problem either.
What do they mean by the spring are walking? The springs might have the wrong spring locator for the application but a lot of things are not answered here. If someone didn't put locators on the heads, someone else got a hold of them and did this most likely.
If you need help with this let me know I can point you toward some people who know what they are doing in the PA area.
Bret
Bret
None of the valves are bent but one does need replaced. It was chipped when the lash cap was removed. I knew this ahead of time. The company doing the work is a sponsor of this site and has a good reputation with a handful of 8 sec cars. They acted like a 7mm valve was too weak. I may be wrong but I'm thinking the valves are titanium but I'm still waiting to hear back on that. I'm at a real loss as to what to do here. I may just have them finish up the shortblock and throw the rest together myself.
Brandon
Originally Posted by SStrokerAce
7mm is not too weak for SB2.2 heads in a cup motor.
Bret
Bret
Brandon
I just confirmed that these valves are titanium. I'm planning on running these heads if my shortblock ever gets done. Even though the shop says they're junk everyone else I've talked to seems to think they're very good heads. I tend to agree with them givin the times the previous owner ran with them.
Have you talked to Craig? I have known him for years and that does not sound like something that would come out of his shop. BTW the 7mm titanium valves are the hot setup on a real race motor. Maybe the shop working on the heads isn't familiar with hardcore race stuff
Well how neat is that. I goto that page and the headline is vette dr's run 9.39 blah blah. I'm pretty certain that was with the set of heads I have in question. I will be in touch with them just to ease my mind.
