TSP Magic Stick or HPE S Cam
im looking at getting either cam thats posted in the title.(Magic Stick or S cam) but i need yalls opinion on which cam is better. i plan on getting a converter with maybe a 3500 stall(i may go bigger if needed), kooks headers, True duals, F.A.S.T intake, and a 100-150 shot. i just wanted to know which one of these two cams would be the best for this setup. and what rocker arms and springs should i go with? and anything else you guys may think is required or recommended. any input is greatly appreciated.Thanx
I have a MTI Z1 that i will sell you. Makes bad *** power on motor (465rwhp/430rwtq in my car w. heads) and the gas comes on HARD with it. The cam only has a 2-3 thousand miles on it....
Originally Posted by skipperbisket
its up to you, its your car
i know its my car and that its up 2 me. i posted the thread for opinions on both cams and which one you guys think would work better with the setup.
Originally Posted by xaon
S-cam = 238/242 113 or 115lsa
MS3 = 237/242 113 or 114lsa
both XE-R lobes.
Buy whichever one you can get cheapest.
As far as springs and rockers. Get something like the Patriot or PRC dual springs, and the stock rocker arms are fine.
both XE-R lobes.
so both cams would make about the same power with that setup?
considering you asked about two cams that the only difference is 1* or intake duration, i would suspect there is really no need to ask since they will both most likely produce about the same #s.
