where to install the methanol nozzle ???
I am installing a D1-SC Procharger system, I will be using the stock twin procharger intercoolers with the ATI black plastic air box.
OK i have a razor methanol injection kit also ,
i know you cant spray methanol through the mass air sensor, so ther is only a little 4" rubber collar-hose that conects the mass air sensor to the throttle body,
I guess this is the best and only place to install the methanol nozzle???
do anyone have pictures or their methanol kit installed
Please post them
thank you
Please post them
thank you
Here are a few shots of a setup that I put on a buddy car. Able to drill and tap the nozzles on the TB.
Not sure if it will help you, dont know how razor nozzles mount.
These were Snow Nozzles that used a 1/4npt. So mounting worked well.
Note some shots do not show the second nozzle installed, Mock Up
