parts to install ls6
Old 03-16-2003, 02:20 PM
Boo Yeah's Avatar
Default parts to install ls6
on a step by step site it said i need a
- 1x 2001+ front coolant pipe - #12568478
- 2x 2001+ rear coolant plugs - #12562788 (Note, you can use a 2nd coolant pipe in place of these plugs if necessary)
is the dealership the best place to get one??
Old 03-17-2003, 02:06 AM
Boo Yeah's Avatar
Default Re: parts to install ls6
come on please <img border="0" title="" alt="[Embarrassed]" src="gr_emb.gif" />
I need to know tonight
Old 03-17-2003, 02:16 AM
Toxic Texan's Avatar
You might be able to get it from slp or from Thunder Racing.
http://www.slponline.com/view_produc...&SHOWEMAIL=Off
Old 03-17-2003, 02:44 AM
Jabroni's Avatar
GMPartsDirect or SDPC. Much cheaper than a delaership.
Old 03-17-2003, 02:48 AM
Boo Yeah's Avatar
yeah but i need them quick
Old 03-17-2003, 02:49 AM
Boo Yeah's Avatar
what is the front coolant pipe for???
I have the TB bypass does that matter.
Old 03-17-2003, 02:59 AM
Boo Yeah's Avatar
I guess i am asking if i can do it with out
Old 03-17-2003, 08:35 AM
Graphite_WS6's Avatar
You need the coolant pipe and both rear coolant plugs to do the install. The pipe cost me about $25 and the two plugs about 3$ each (I get parts at dealership cost though, so it might be higher). It doesn't matter if you have done the TB coolant bypass mod or not, you still need the front coolant pipe. If you do the install yourself, be careful removing the intake. I broke my oil pressure sender when I removed the old intake. Also, do not over torque the 10 intake bolts because it can cause a vacuum leak. Hope this helps. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
