decents heads for t2 cam?
what would be a decent overall head for a torquer 2 cam? something that would get my dcr maybe a little closer to optimul and maybe even give me a tad more compression? im not trying to break the bank but if something is worlds better than others let me know.
Originally Posted by ls2 bait
because i know what ur answer would be. et heads or the 5 extra pair of ls1 heads u have laying there
Acturally I know you better then that and I know your not trying to spend ET money. (Although if you were I would defentially suggest them)
I also know that your trying to get a better head then the extra sets I have siting around.
I would suggest the ET's but for a cheeper rate I would suggest either the Dart 205's, TEA stage 1 LS6 heads, or TSP stage 1 heads with their comp valve job. (For the 100 bucks I would always get the valve job)
The stock valves work pretty well so there is no reason to spend the extra money on the valves in your position.
Give me a call or swing by I will do what I can to help you make the right decision.
