Spohn TA & True Duals???
Okay, I've done a search and have come up with a post from back in October on this issue. But I haven't seen it brought up again.
Has anyone been able to complete a true dual set-up with the mount of the Spohn TA not being located on the tranny any longer, but instead where the "cross brace" was located. If so, do you have any pics?
TIA,
John
TIA,
John
Re: Spohn TA & True Duals???
Would also like to know. My trueduals will be on by the end of the month and I need to finish my suspension work.
This should be no problem to do at all you will just lose a little ground clearance due to the crossbrace but you could always go with 2.5" to gain the clearance back.
Hey Thanks Justin. That's what I was told I should use coming out of the x-pipe anyway (2.5")...3" from the headers to the x-pipe, then 2.5" out of the x-pipe to the mufflers. Any comments on that with the mods in my sig?
