Why have EGR and AIR?
hey i have a 00 TA and am planning on getting a set of headers for it soon and will probably go with the off road application but was wondering what the point or advantage/disadvantage of having EGR/AIR
Thanks wldesyWS6
Thanks wldesyWS6
Originally Posted by spy2520
no EGR/AIR means less clutter under the hood and less **** to worry about...i dont think i've ever heard of a benefit unless it you have strict emissions laws.
There are zero advantages to having AIR and EGR, that is why everyone takes them off and tunes them out. Why would there be an advantage? they are only to help control emissions...so I guess if you feel you are heavily contributing to global warming you should leave them on, but if that is the case you should buy a honda, or up the horsepower and ride your bike...
Sorry did that come off sarcastic? I really didnt mean to be a smartass towards you, I just dont really like the fact that they were put on the car in the first place, ya know?
And I've been at work all day, that never helps the mood...
Little off topic but does any one know what changes were made between 00 and 01 engines as to why they took off egr after 00?? does the emissions really raise enough to fail a 00 car without the egr?
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Most definitely drivable without that stuff. You can't even tell a difference and it doesn't drive any differently. Only thing is you'll have the SES light on, which scares some people, but isn't a big deal.
So if I delete my EGR, is there a way to make it look like the 01-02 under the hood so I could pass any inspection? or do they have block off's and such too. Would there be a need to clear any codes after and LS6 manifold and egr delete?
It was the cam, but I beleive it has a longer duration than the 98-02 models. That is why those cars, combined with the LS6 intake and better manifiolds will tend to dyno better stock numbers than 98-00 cars.
Originally Posted by 00454sscamaro
they changed the cam in 01 and apparently it didnt need it after the diferent cam, the better ls6 intake made up for the different cam. i read it was a slightly smaller cam to increase durability and the better emisions came with it.
