New LS1 Owners - Newbie Tech - Can my Local GM Dealer install Aftermarket Heads?
silverta16
06-12-2006, 01:55 PM
Just wondering if a local GM garage would install heads on my 98 SS? Don't really want to tackle it myself, do they just do GM parts installs or maybe? Maybe a head and cam swap? Thanks
CrawlinWS6
06-12-2006, 02:01 PM
From reading the title of this thread. Yes, I am sure the dealer will install heads and cam. But you will get royally anal rapped having them do the work! If don't have a speed shop near you, then for should be able to go to a full service mechanic to do the swap and save alot of money. But I would suggest going with a speed shop instead.
HandsomeBWouderful
06-12-2006, 02:05 PM
Ditto.
Are they capable of doing it? Yes, I'm sure they are. Will you pay a premium for their services? You betcha.
Nasty N8
06-12-2006, 02:18 PM
Check with Force Fed High Performance I am not sure how far you are from them but they are a great shop to work with.
Nate
joelvette
06-12-2006, 02:54 PM
call your dealership and ask them the price for doing that, then your local speed shop, then find your local ls1 guru. if you helped him on the weekend you'de probably save enough to do other mods too. start searching theres gotta be someone close to you who does things like that all the time, maybe even one of the tech guys at the dealership driving a modded fbody.
TheBlurLS1
06-12-2006, 04:01 PM
Do it yourself. I ENJOY working on my car, well sometimes........
You might want to try to post in the regional sections or maby do a sponsor search by zipcode.
Mike02Z
06-12-2006, 04:41 PM
I'm sure the dealer can do it but be prepared to take it up the butt big time! You're better off finding someone local who works on lots of LSx's. Most time these folks will have fixed prices to do heads, cam, long tubes etc. The last thing you want is the dealer just charging you by the hour while an inexperienced tech. cuts his teeth on your car. Add to that the fact that the dealer will typically have the highest hourly rates of any shop in your area and you could get boned big time. If the dealer will give you a flat rate then compare that to a local LSx speciality shop but it's been my expereince that the dealer will give you a ballpark estimate but then charge actual hours.
While I agree doing it yourself is the best way to save the most money and learn something about your car I also understand that not everyone has the tools or ability to tackle such a complicated proceedure as swaping heads.
Good luck to ya!
'Trust'
06-12-2006, 05:15 PM
H/C swap in itself is not hard, just follow instructions on LS1HOWTO.com, its pretty hard to mess it up, but... it IS time consuming, very infact. I'm sure H/C could be done in a day, but if your not used to something like that, set yourself a week.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
