7000RPM Guys - Blowing Out Spark?
Old 06-12-2006, 02:02 PM
JoeyAnderson's Avatar
Exclamation 7000RPM Guys - Blowing Out Spark?
Guys that are turning 7000RPM on the stock shortblock - I need your help.
I'm running NGK TR55 plugs gapped at .055, and shifting ~6900RPM. In the neighborhood of 6600-6800RPM (both on the dyno and the street), there is a very slight miss that only lasts a split second. I think you can see it reflected in this dyno graph.
My tuner recommends tightening the gap to ~.045 and trying that, which I will. My question for you all is this: is there anything else it could be? I'm sure some of you have experienced something like this before.
The car has TSP's hardened pushrods, so I think we can eliminate a bent pushrod as a possibility. Any other ideas? Thanks in advance folks!
Old 06-12-2006, 03:08 PM
NVR_SPDS's Avatar
Im not a pro on high RPM stuff, but on my Lightning, at 14psi i was getting spark blowout, so i tightened the gap, and havent had a problem since. I dont see anything else causing the problem. If the tighter gap doesnt solve the problem, then id start looking at your coil packs.
Old 06-12-2006, 03:28 PM
Restricted User
CAT3's Avatar
with the graph smoothed on 5, its not easy to tell....if you can get it sans smoothing would be better. Other than spark blowout, what about valve springs? Ran mine up to 7300 TR6' gapped @ .032".
Old 06-12-2006, 04:00 PM
Here is the graph with the smoothing turned off. The blue pull stopped before 7000RPM, the green did not. The dynos were within minutes of each other.
Valve Springs are the Precision Race Components Double Springs rated to .660" lift (with Titanium Retainers, Spring Seats, Seals).
Old 06-12-2006, 04:41 PM
s346k's Avatar
it looks like you need to be shifting before 6,800 anyhow...more like 6,600 or so..
but i would guess regapping your plugs will greatly help, if not solve your problem.
Old 06-12-2006, 06:23 PM
sickss228's Avatar
Yeah try regapping. I dont see a problem shifting at 6800 thats about 500 rpm past your peak hp, right around where you want to be.
Old 06-12-2006, 08:04 PM
Restricted User
CAT3's Avatar
Thanks, just wanted to confirm it does not look like valve float. We had a couple guys on the rollers when I dyno'd mine that went into VF issues, very choppy. I agree with ^, shift earlier and try the regap out.
Old 06-12-2006, 08:22 PM
s346k's Avatar
i think that only applies when 500 rpm past peak isn't 25 rwhp below peak, as well..
Old 06-12-2006, 08:25 PM
gnx7's Avatar
My redline is 7100rpm and I'm running TR6's gapped at .035" I believe. Pulls to the top easily.
TSP 233/239 112LSA .603/.600 cam, AFR 205's + usual mods
Old 06-12-2006, 08:52 PM
cantdrv65's Avatar
Post
I experience some valve train instability around 6800 rpms using PRC duals. I have been thinking of shimming them up some to help. I was running TR55s and also went to TR6s gapped at .035. havent hit the dyno again since the plug change. My graph was more choppy than yours up top, but honestly Im not too worried about it as well because my car makes peak power at 6250 rpms.
Old 06-13-2006, 10:24 AM
Blackboosted2's Avatar
I dont think i've ever had an issue with spark blowing out at 7100+ stock bottom end. I think I'm just looking for an excuse to build the engine...stupid Trex cam
Old 06-13-2006, 11:09 AM
PREDATOR-Z's Avatar
You are not benefiting by shifting that high. Cam is obviously dipping after 6500. so i would shift 6700 or so.
No need to kill your motor for nothing.
Old 06-13-2006, 12:29 PM
So that extra 200RPM is "killing my motor"?
I will try shifting lower and seeing if that helps ET, but I very seriously doubt that the situation is as extreme as you make it sound.
Old 06-13-2006, 08:43 PM
masterdill's Avatar
PREDATOR-Z is a joke, you didn't get the memo?
Old 06-13-2006, 08:47 PM
ls2 bait's Avatar
**** u guys are running tight gaps on ur cam cars. i didnt change the gap on my tr55's when i installed the torquer. they are at .50-.55. should i swap them out or tighten them up? maybe this attributes to my poor dyno some.
back to the question at hand i shift mine at 6700 and i dont think anything is wrong with it. atleast not that i can tell.
Old 06-14-2006, 02:24 AM
PREDATOR-Z's Avatar
please explain.
Old 06-14-2006, 09:22 AM
GuitsBoy's Avatar
Thats news to me...
Old 06-14-2006, 11:23 AM
PREDATOR-Z's Avatar
Maybe he meant:
Predator-z, he is a joke ??
If I'm a joke, I hope it's a good one. To make poeple laugh is a blessing.
Old 06-14-2006, 11:30 AM
GuitsBoy's Avatar
Maybe he meant:
Well, judging by your avatar, youre not what I could deem an attractive man.
Old 06-14-2006, 11:38 AM
PREDATOR-Z's Avatar
Nice hear cut, don't you think? It's a "Perm"
