Dynomouth vs. loudmouth
I'm thinking about getting one or the other. My biggest question is, is there a big difference between the sounds of the two systems? I can only think there is if people are going through the trouble to put the Dynomax bullet on.
Also, if you build a Dynomouth, does it matter where the bullet resides on the main tube, or is it limited to a certain portion of the pipe.
Thanks,
TurboSteve
Thanks,
TurboSteve
Re: Dynomouth vs. loudmouth
I swapped out my LM with a dynomax resonator. I can say that the sound is more toned down, less rasp, less popping. I think it sounds much better.
