160 degree thermo and fan congtrol !!!!
were do you set the fan control for 2002 z28 with a 160 degree
stat, and what bennies from this temp besides keeping the block cool,
and a final question what changes do you see when scanning and editing..
and what coolant do u guys use, i got the pink ****, thinking about
adding some of that new stuff that goes in the coolant to cool better....
thanks.......
thanks.......
Not really anything to look for....except maybe a little less KR. I'd knock about 25 degrees off the stock settings for a 160 stat. Too much lower and the fans will be running more often than not.
Stock Cooling Fan Temperatures:
Fan 1 on/off at: 227°F/218°F
Fan 2 on/off at: 235°F/228°F
Hypertech's from their instructions for the HPP3.
Stock 195° thermostat
Fan 1 on/off at: 209°F/200°F
Fan 2 on/off at: 219°F/210°F
180° Hypertech PowerStat
Fan 1 on/off at: 194°F/185°F
Fan 2 on/off at: 204°F/195°F
160° Hypertech PowerStat
Fan 1 on/off at: 184°F/175°F
Fan 2 on/off at: 194°F/185°F
depending on what tuning software you are running you will have to convert those numbers...which isn't a big deal.. lol. just had to mention it.
also, i usually run a littler lower fan temp settings...my car never goes above 195(if even at it for a few seconds) on HOT days and in traffic
