DENSO IRIDIUM PLUGS
Old 03-20-2003, 07:14 PM
SILVER's Avatar
Default DENSO IRIDIUM PLUGS
DOES ANYONE KNOW HOW MUCH THESE PLUGS ARE?
FOR 2000 Z28 M6.
THANKS FOR THE INFO. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old 03-20-2003, 08:05 PM
DrkPhx's Avatar
Default Re: DENSO IRIDIUM PLUGS
Average price is $96 for the set. One of Predator distributors has them for $78/set shipped.
Old 03-20-2003, 11:14 PM
Iv_z28's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by SILVER:
<strong> DOES ANYONE KNOW HOW MUCH THESE PLUGS ARE?
FOR 2000 Z28 M6.
THANKS FOR THE INFO. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I believe NGK iridium, which use the same idea, are $6/piece => $48 /set at Thunder racing.
Old 03-21-2003, 09:02 AM
QIKSILVR's Avatar
Are the NGK Iridium plugs that much better than Platinum? Are the worth the $$. Will you really notice any difference? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old 03-21-2003, 08:42 PM
KCA13's Avatar
Denso's iridiums are the best spark plugs you can buy. There about $10 a peice, but are excellent, you can run them with Nitrous or Superchargers/Turbos.
Old 03-22-2003, 12:52 AM
OliGeorgs's Avatar
What is the story w/iridium?
Old 03-23-2003, 03:18 AM
Judd's Avatar
Supposedly they give the conductivity/power of a copper plug while lasting as long as a platinum plug. A Mustang mag did a test on them and did gain some HP, quite a bit actually. The test was a best case scenario for the plugs though- a blown motor with lots of cylinder pressure.
I'm a bit leary of power gains on a stock LS1 over copper plugs though. I used to road race production bikes. I the production classes you can't do alot of stuff to the motor. I tried almost every widget know to man within the rules. Split Fires, platinum plugs, timing advancers, advancing and retarding the cams, drop-in K&N filters, heck I even tried Slick 50. Every change was tested on a dyno, the only widget that worked was-20W Redline oil. Picked up 2-3 HP over 10W40 Motul. That's it. Widgets suck!
If I see some tests were they actually give power in a normal scenerio-then and only then will I pay 10 bucks a plug. One dollar copper plugs work just fine for me, just have to change them more often. Perpetually Cautious, but willing to change my mind!
Old 03-24-2003, 12:10 AM
2000WhiteZ28's Avatar
I agree with the above, if you want power get copper. If want no maintenance, get platinum.
Old 09-25-2005, 12:54 PM
damon_Z's Avatar
Do you know which of the Predator distributors had them for $78 shipped? Is the distributor a sponsor? Thanks in advance for the info.
Old 09-25-2005, 03:15 PM
Moderator
davered00ss's Avatar
$12-$13 ea.
Old 09-25-2005, 05:10 PM
DrkPhx's Avatar
His user name was RWTD, but that a couple of years ago. I switched to NGK Iridiums for my new setup.
