How do I get this bitch off
Old 06-13-2006, 12:02 PM
Red97Z's Avatar
Default How do I get this bitch off
Ok, I removed all of the bolts securing the crank pulley, but it won't budge, as I expected it wouldn't. So my question is, what's the easiest, fastest way to get it off?
Old 06-13-2006, 12:05 PM
-PEPE-'s Avatar
crank pulley puller, WD-40, you can rent the puller or just buy one and your local Orielly or Autozone.
Old 06-13-2006, 12:42 PM
Hot94Z28's Avatar
Yeah I had to use a puller came right off
Old 06-13-2006, 12:44 PM
M29_Formula's Avatar
I just tapped around it with a rubber mallet and it loosened up enough to wiggle off.
Old 06-13-2006, 12:45 PM
Red97Z's Avatar
Thanks, I'm going to try a rubber mallet since I already have one, and if that don't work, well I guess I'll have to get a crank puller tool, how much do these guys cost?
Old 06-13-2006, 02:47 PM
hashtagBMW
Speed Density's Avatar
I did a rubber mallet on mine, got a stubb *** screw driver and hit it on the bottom then roatated it and repeated the procedure.
Old 06-13-2006, 03:10 PM
TurboZ28's Avatar
They're free. You rent them from autozone. You put down a $20 deposit and when you return it they give it back to you.
Old 06-13-2006, 03:13 PM
Dragframe's Avatar
that is what i would suggest
Old 06-13-2006, 04:41 PM
dhdenney's Avatar
Rubber mallet works well for the pulley, if you want the hub out, you'll need the puller.
Old 06-13-2006, 07:00 PM
MEAN LT1's Avatar
Rubber mallet.
Quick Reply: How do I get this bitch off
