HELP: can't get crank bolt out
Breaker bar with a decent pipe over it. I use the pipe off my jack. You could also try to jam the breaker bar and use the starter to break it loose. Make sure coil packs are unpluged and fuel pump fuse is out.
get a more powerful impact wrench and or get your air pressure higher. Impact wrench is the way to go cause there is much less chance of twisting off a bolt with and impact wrench than just hulking on it with larger breaker bars.
