About to get a tune, what to do?
Old 06-13-2006, 05:45 PM
bigburb's Avatar
Question About to get a tune, what to do?
I'm about to get a mail order tune. I know to send in the specs of the cam, exhaust, octane rating. What else do I need to give them? I know I need the !EGR and !AIR delete, but what else is there that I can do with it?
Old 06-13-2006, 07:45 PM
WS6FirebirdTA00's Avatar
Dont give them anything. Get a REAL local tune, unless you dont really care. I dont care what anyone says, you cant get close from a mail order tune unless you are lucky. I would rather spend the money doing it all right.
Old 06-14-2006, 03:41 AM
1sick'98WS6's Avatar
agreed ^^^
Old 06-14-2006, 06:50 AM
1QUIKWS6's Avatar
I second that!
Only reason to get a mail order tune would be to get the car to at least run and be in 'safe mode' after an install - just to get you to the shop that is gonna do the proper dyno tune.
Old 06-14-2006, 11:18 AM
bigburb's Avatar
ok so you mean a real tune from a local shop, not a dyno tune right? i don't have enough for a dyno tune.
Old 06-14-2006, 11:30 AM
1QUIKWS6's Avatar
The only 'real' tune IS a dyno tune so that they can properly dial in A/F ratio, etc. based on readings from wideband.
Unless you know of a shop that will install a WB O2 setup for you & drive around in your car with a laptop and log your values - then tune - go back and drive again - the tweak tune, etc.
They could change paramters such as !EGR, !A.I.R., Fan Settings, Tranny Settings at a shop from a laptop (or you could do some of those items yourself using a Diablo Predator Handheld Tuner for eg.) - but to properly tune the engine you will need the WB O2 readings.
If you are going to do major mods other than bolt-ons you should always plan on $500 for a good thorough dyno tune in your budget before doing any of the modifications. It sounds like a lot right now, but depending on what parts you have installed it could mean the difference between a sweet running, powerful engine and a blown engine!
Old 06-14-2006, 01:25 PM
bigburb's Avatar
i'll just save up for now i guess... mail order tune for now just to get it running right, only 75 bucks, and couldn't possibly run any worse than it is already. has cam, heads, exhaust and intake manifold, programmed by vinci programmer but the cam is just outside of how far the prgrammer can go.
Old 06-14-2006, 01:39 PM
z28hottie's Avatar
what do you do if there is nobody within 500 miles that knows how to properly tune your car?
Old 06-14-2006, 01:42 PM
ZL1Killa's Avatar
you **** out of luck. move or forget modding your car. LMAO.
i really don't know.
learn yourself and ask others online using LS1Tech.com!!!
Old 06-14-2006, 01:51 PM
z28hottie's Avatar
i have done that in the past....i have lt1 edit but when i have posted in the past asking for help i dont get any, its probably cuz im a girl
Old 06-14-2006, 02:35 PM
LS1TECH Sponsor
foff667's Avatar
blah girls yuck
Old 06-14-2006, 03:25 PM
z28hottie's Avatar
Originally Posted by foff667
blah girls yuck
thanks
Old 06-14-2006, 04:52 PM
Zzzzz's Avatar
With the capability of the tuning software available for these cars, I'd think you can do a pretty good DIY job of it in combination with a wideband.
Old 06-14-2006, 05:06 PM
bigburb's Avatar
well, i just bought this car because i was tired of having a project, i just want something fun to drive. not looking to spend a lot of money to get it running exactly *perfect*. however, if a mail order tune has the possibility of hurting my car, i won't do it.
Old 06-14-2006, 10:27 PM
ZL1Killa's Avatar
where are you located?
if you are near charlotte, I recommend Nick Williams or Alvin@pcmforless or Mike (WS6FirebirdTA00) up on these boards.
near raleigh i would recommend RPM (Ryans performance machines)
CAM(carolina motorsports)- can sometimes be bad, but recently had 2 guys go there and there cars put out some good numbers so I will no longer say its bad.
Old 06-15-2006, 05:02 AM
bigburb's Avatar
i'm in houston tx
Old 06-15-2006, 05:11 AM
1QUIKWS6's Avatar
When I installed my ATI on the other T/A, I used a custom tune downloaded to my Diablo to get the car running half decently - then drove SLOWLY to the reputable tuner in the next state to get the 'correct' tune. Worked for me.
and BTW Girls = Me just loves girls that get into wrenching on the car - as long as they don't resemble Goober the mechanic from Mayberry the rest of the time
Old 06-15-2006, 07:14 AM
RedWS6 00's Avatar
thanks
If you were local I would give you a hand tuning.
