ASP pulley question....
Excuse my ignorance....when changing the alternator and crank pulleys, is this a mod that the computer must "re-learn" to obtain its full performance?
Re: ASP pulley question....
correct me if im wrong, but dont the use of the alternator and the crank pully push the full charge mark up to like 950-1000rpm or so. Just a FYI for if you have a system
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by stang killer:
<strong> correct me if im wrong, but dont the use of the alternator and the crank pully push the full charge mark up to like 950-1000rpm or so. Just a FYI for if you have a system </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Im not quite understanding what you are saying. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
P.S. I have no stereo modifications.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by ULTIMATEORANGESS:
<strong> i was told with an ASP crank pulley you wont get a full charge till 900 RPMs. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I see in your sig that you have the ASP crank pulley, do you have the alternator pulley as well?
How do you like the ASP pulley? Also do you have an A4 or M6?
if you have an automatic, you need to be aware of the fact that full charge will not occur at idle in drive, for M6 cars, this is not a problem.
I have not heard that pulleys will contribute to knock retard, unless you put them on wrong I suppose.
Everyone I talk to on the subject suggests to only use the ASP crank pulley and not to bother with changing the alternator pulley. Less complications apparently.
<img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Camaro SS 2002:
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by ULTIMATEORANGESS:
How do you like the ASP pulley? Also do you have an A4 or M6? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">i have an a4.i forgot to list it earlier. <img border="0" alt="[bang head]" title="" src="graemlins/gr_banghead.gif" /> just crank only i have.i noticed the faster guys were using these pullies and its fairly cheap so i went with it.its a good mod imo.i had my idle turned up slightly when i had tuning done.it might need to be turned up more but it only drains alot with everything on at a standstill.definitely a worthwhile mod.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by DaddySS:
<strong> if you have an automatic, you need to be aware of the fact that full charge will not occur at idle in drive, for M6 cars, this is not a problem.
I have not heard that pulleys will contribute to knock retard, unless you put them on wrong I suppose. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">This is what I have heard as well. Do you have the ASP alternator AND crank pulley? If so, any charging issues at all?
P.S. FWIW, I have an M6.
After my ASP pulley install, my steering wheel has play in it, from stop and roll. It can move either way about 1/2" until it grabs, and the car starts to turn.
Anyone else like this?
We did it at the same time as headers, but we adjusted the steering rack properly.
