Drag Racing Tech
Rim screws???
Old 06-14-2006, 07:23 AM
JRracing's Avatar
Default Rim screws???
I have a used set of draglites and a new set of 28x10.5 ET Drags mounted on them. The wheels have about 10 holes in each side from the previous owner. Most of the wheels I see only have about 6 holes in each side.
I have two sets of screws. But I'm not sure how to go about mounting them.
How many should I use per side? And in what kinda pattern?
I don't want to trash these new tires.
Old 06-14-2006, 08:18 AM
Tom the roofer's Avatar
When I had draglites I had 8 screws on each side. I centered a straight edge over the holes in the draglites "eyeballed" and made 2 dots where I was going to drill. I repeated this procedure until I had 8 dots evenly spaced on each side of the wheel. Make sure the holes are lined up even on the inside and outside.
Old 06-14-2006, 04:36 PM
JRracing's Avatar
The holes in mine look to be off set from the inside to the out side.
