TSP ORY vs Pacesetter ORY
Which one should i get? which is a better quality piece and does one fit better/better clearance than the other? Thanks!
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
well tsp sells their pipe with pacesetters in a package... there must be a reason for it.. by the way.. theirs is fully adjustable and fits my car great.. i dont have any banging either like some people have talked about..
I wanted the TSP ORY from what I heard it had smoother merge at the y point. but TSP was out of stock so I got the pacesetter ORY its made from 2 pieces so it has some adjustment. I did poly motor mounts when I put my headers on and I have no banging problems. And it tucks up good on my T/A with the stock sideskirts on level ground from 10-20 feet back I(5'9") have to kneel a little to see it. I'm happy with it and have no complaints. I would have liked to have ordered the headers and TSP ORY as a package from TSP as it was have been a little cheaper. I would call TSP and see if they have them in stock. if not don't there are no big problems with pacesetter ORY
ok, well both sponsors have the same price.... Speed inc sells pacesetter LT and pacesetter ORY combo for 500 and TSP sells pacesetter LT and TSP ORY for 500 as well, just curious if one was a lot nicer than the other
__________________
That's what she said...
From what I've read/seen, the Pacesetter y-pipe rides much higher than the TSP unit. The Pacesetter Y has a slightly crushed section to clear that damn body brace under the driver floorboard. Since you're on sportlines, I would definatly go for that. I would also throw in a set of poly motor mounts too.
Motor mounts are uber-easy with no headers/manifolds and uber-hard with them. They are a great mod and cheap too ($50).
whats the benefit of them? excuse my newbiness on motor mounts
__________________
ok thanks for the help!
__________________
