13111 Vette O2's or Stock?
I was planning on using the corvette rear bosch#13111 O2 because of their longer cables....but after searching older posts some people said that the vette o2's are leading to the cycle/not heating up code being thrown more often than with stock type O2's
Any Advice and what O2 will work best with stainless headers?
Thanks
Thanks
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
just the opposite....13111 have wider/higher heat range..been told this here..and local shop knew this also...putting mine [lts] on tommorrow with them..
I've had many problems with my stock O2's since my header install last year. I'm going with the bosch 13111's eventually.
They're supposed to have a lot better heater element in them.
ok I thought 13111's were the way to go, untill i read a few older posts when I did a search. Like you guys said tho, you would think the o2 having a better heating element would keep that sim a lil more toasty.
