how to install a water temp gauge?
Old 06-15-2006, 11:16 AM
erikthegoalie's Avatar
Default how to install a water temp gauge?
any write ups...where do i drill?
i am doing heads and cam soon...should i do it then?
also shoudl i buy a 160* TStat???
THANKS
Old 06-15-2006, 11:28 AM
JakeY2KZ's Avatar
160* is up to you. In order for that to fully work, you're going to need to add a manual fan switch or get a tune so that your fans are adjusted accordingly.
As for the temp guage, there's 2 places you can put the sending unit at. One is on the back of the passenger side head. This is where most put there's at. There's a plug by the #8 plug that you will need to take out. If you put the sending unit there, you'll need an adapter kit for the sending unit. Search for it, there's many links to buy the kit. The second place is behind the starter. Of course you'll have to drop the starter to get to it and I'm not too sure if you will need the adapter kit for this location.
Or there's one more route you can take, I've seen it done on one car so far. You can tap on the top of the water pump and stick the sending unit there. Either one is up to you.
I would suggest since you're doing a head swap soon, just to wait then. You will have easy access to the location by the #8 plug. It'll be easy to install the sending unit while the head is off the car.
Old 06-15-2006, 01:01 PM
BitViper's Avatar
Ive asked this b4 but never got an answer..cant you just splice (using the correct harware of course) into the water tube that runs thru the TB Vs drilling?
Just wondering
Old 06-15-2006, 01:03 PM
That's what she said...
TheBlurLS1's Avatar
If you look at the stock water temp sending unit, where it screws into the head, then imagine the exact opposite corner of the motor, you'll find the plug.
One guy put his in line with the front coolant pipe, not sure how well it's working for him, but it was super easy.
Old 06-15-2006, 01:59 PM
cool thanks guys!
Old 07-25-2006, 08:19 PM
Lukin's Avatar
Can anyone verify when you are installing it under the starter weather you still need an adapter. And if you do is it the same as the one needed for the head?
Thanks
Adam
Old 07-26-2006, 05:58 AM
Lukin's Avatar
Anyone?
Old 07-26-2006, 06:23 AM
Frosty's Avatar
Thanks
Adam
Yes you do need an adapter and it's a different size than the one on the back side of the head.
Old 07-26-2006, 08:08 AM
Weezzer's Avatar
Thanks
Adam
The one by the starter is 16 mm by 1.25 pitch (I believe) male with 1/8 -27 NPT female. The one for the head is 12 mm with 1.25 pitch thread male by 1/8-27 NPT female.
fittingsandadapters.com has steel adapters - much better than the brass adapters that are so easy to break.
Old 07-26-2006, 08:29 AM
Mr Ed's Avatar
Actually, it’s a 1.5 pitch. I bought mine from Jeg’s and paid an outrageous price for it ($11.99). However, I was making an order anyway so there was no additional handling or shipping charges. You can find it elsewhere for $5.00 or so but then you get hit for another $7-$10 in shipping which would have wiped out any savings for me.
Link: Adaptor (Jeg's Part # 105-2268)
Old 07-26-2006, 05:01 PM
Lukin's Avatar
Ok great. Thanks for the help.
Old 07-26-2006, 10:36 PM
2kta--89formula's Avatar
Could someone post a pic of this location?
Old 07-27-2006, 09:10 AM
LS69TA's Avatar
Mine's working great. Cost about $5 in parts too I used brass fittings I got at the local hardware store. I got a 3/8" "T" fitting, used one port to put the sending unit in, and 2 3/8" barbed hose ends to connect to the hose coming from the crossover line going to the TB and radiator. You effectively do a TB bypass when doing this also, so you kill 2 birds with 1 stone. Mine is currently tucked under the bellows, out of sight. You just have to also drill and tap a hole to mount a ground wire to. A small self-tapping screw with a dab of teflon pipe sealant worked perfectly.
Old 07-27-2006, 11:32 AM
BitViper's Avatar
Just wondering
So it can be done
Old 07-27-2006, 11:40 AM
LS69TA's Avatar
Yep, and it's a helluva lot easier to do.
Old 07-29-2006, 10:08 AM
Lukin's Avatar
I will post one when I install it. The adapter is going to be here on the second so it may be a little while.
Old 07-30-2006, 12:38 AM
wow glad this thred is still going...
i want to install my sending unit in the head....where can i buy the adapting kit?
Old 08-02-2006, 02:12 AM
Starz T/A 17's Avatar
yeah me too, im goin to do mine this weekend
Old 08-02-2006, 10:56 AM
Rabidbandit's Avatar
On one of our cars we threw it in the top of the thermostat housing. Worked like a champ and gave us the temp of the coolant coming out of the block before it hits the radiator. Showed how off the factory gauge really was...yikes
Old 08-02-2006, 11:41 AM
LS69TA's Avatar
Yea, the facory gauge is a joke.
Quick Reply: how to install a water temp gauge?
