02 sensor install?
Re: 02 sensor install?
There are a total of four of them. Two before the cats, and two after. The two after the cats are pretty easy to see, the two before the cats are tucked up in there.
There is a special O2 sensor socket that you can buy. It has a slit in the side for the wire to fit into so you can remove the sensor with a ratchet. It costs $15-25. It is well worth it, especially for the upper O2 sensors that you can barely reach....
Tommy <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
