Head Question
Head Question
i'M THINKING OF BUYING SOME TEA STAGE 2 HEADS. i HAVE A TSP 231/237 CAM IN MY CAR RIGHT NOW. I WAS WONDERING IF I WOULD HAVE ANY VALVE CLEARENCE PROMBLEMS. AND WHAT SIZE GASKET I WOULD NEED TO RUN. IM ALSO GOING TO BE SPRAYING AND DONT WANT TO HIGH OF COMPRESSION
the tea heads work well with that cam.i don't know about clearance ,i've seen a combo or 2 with that setup so you might be able to use the search and pm the person with that combo and see what gaskets they used,how much heads were milled .
i ran mti 5.3 heads with slightly larger duraration cam, and i didn't have any problems, but im sure there is a formula or method that is on the this site to let u know for sure.
