morel lifters
morel lifters
has anyone dyno tested morels? I have mine set at .030 preload, an it seems as if I'm getting valve float around 6600 rpm? Thr car peaks just under 6600, then dramtically falls off by about 30hp at 6800 then picks up again. Alos, if I have valve flaot, would my a/f be affected? I'm running comp beehive springs.
twofast4lv, did you play aroubnd with the valves on the dyno to see where they made most power? Are there any disadvantages of running close to zero lash other than a much louder valvetrain?
I did not want to run Zero lash. makes more power for many but I have never been a fan of being on the verge of to much lash with Hydro's. My Valve train is really quiet now. Much better then with the Comp "R"s or OEM style lifters. If it were not for the car shaking and a give away idle you would not know what was about to hit you
BTW the Morels did not really seem to be to much heavier then the Comp "R"s I took out.
