Fueling & Injection - fuel injectors...
ZL1Killa
06-16-2006, 12:36 AM
I currently have RAcetronix 36.5#ers and they are soon not to be enough for what i'm going to be upgrading to. these racetronix also don't seem to like fuel swings quick, as they were causing my p1133 and p1153 codes
what would yall recommend? high impedence or low impedence?
i have heard a lot about the motron 60#ers, i heard you can install them and flash the car with the updated IFR and they are good to go and don't cause any problems
I would indeed jump up to the Siemens 60lb injectors. $420.00 is a great price, and they do tune really well. Bob
ZL1Killa
06-18-2006, 06:14 PM
have you had any codes thrown from them not going to low enough switching for the 02s to switch rich to lean and lean to rich (its called proportional fueling in HPTuners)
i have racetronix right now 36.5#ers and they don't like going to a low enough point to where the computer likes to switch from lean to rich and rich to lean
(at least i think this is my problem, as WS6FirebirdTA00 had the same problem)
1slowls1
06-19-2006, 04:47 AM
ive got ls1tech 42.5#'s uninstalled anybody have a problem with them??
ZL1Killa
06-19-2006, 10:17 PM
?? ls1tech makes 42.5# injectors??
what in the hell? i'm confused as crap now.
ZL1Killa
06-21-2006, 12:34 AM
my question is has anyone had issues with the motron/siemens 60# injectors?
when you tune them you simply will need to change the IFR and they will be fine?
ZL1Killa
06-21-2006, 12:38 PM
tttttt
1slowls1
06-25-2006, 07:56 PM
I dont know if they make them but its on there site under there name.
onfire
06-25-2006, 08:22 PM
Mototron 60's here....just set the IFR and they ran great.
ZL1Killa
06-25-2006, 11:10 PM
are they disc type injectors?
and does LS1TEch.com sell there own injectors?.. thats pretty damn cool if they do
1slowls1
07-05-2006, 08:29 AM
I think they do, I wrote to the pres of ls1tech and he kept refering them as there injectors so very vell could be there own.
ZL1Killa
07-05-2006, 02:40 PM
the motrons are rated @ 43.5psi NOT 58psi
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
