retainers
Old 06-16-2006, 09:49 AM
2000WS6TA's Avatar
Default retainers
are new retainers nessecary when installing a new cam? i wa planning on new vlaves and rods but are the retainers needed?
Old 06-16-2006, 09:57 PM
SSDoubleK's Avatar
Wink
I would, get the titanium ones, your valvetrain will appreaciate you, I did and was extremly happy I did. If your gonna do a cam job, don't cut corners, you'll be happy with changing your retainers.
Old 06-16-2006, 09:59 PM
NviouSS's Avatar
don't forget about the springs too.
Old 06-16-2006, 10:02 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Titanium isn't necessary, I did it for an extra light valve train and that insurance for valve float. you can get the OEM ones and be just fine. I would get different springs like the 918's if you plan on a cam for sure.
Old 06-16-2006, 10:14 PM
blkZ28spt's Avatar
New retainers are not necessary if the springs (NECESSARY!) that you get can use stock retainers. Ti retainers are not a bad idea, though. They are not very expensive and reduce valvetrain weight.
Why are you planning on new valves?
Old 06-16-2006, 10:16 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
If you are doing new valves and plan on going bigger you might want to make sure that you have a combo that is going to help and not hurt with oversized valves.
Old 06-19-2006, 06:49 AM
2000WS6TA's Avatar
my bad on the original post, i ment new valve springs and rods. i was gonna keep the stock valves. but thanks for the help on the retainers.
