What rear gears = M6 + turbo
Well, I have a cam, Lq9 heads sitting at the house. I have the oppurtunity to get 4.10's in the rearend for cheap! The Turbo prospect has been pushed back at least a year. I'm buying a set of coated LT's shortly to be installed as well and was wondering if I would regret the 4.10's once the turbo (STS t67) was installed. Most sign's around the forum tell me not to do it so I figured I'd get some feedback before I pass on the chance. 2002 Camaro SS
Don't do it. You wouldn't see full boost by 3500-4000 in second or third gear. Turbos require loading the engine and higher gears shorten the powerband per gear. Stay way under 373s. I'm running 342s but as soon as the 9in gets here, its set with 3.50s. Do some searching on this, you'll finds tons.
id say you could use 4 10's if your turbo was smaller, cause it wouldnt need as much load/time on the engine to build boost on a stock cubed motor, but im using 3 42's in my setup and it works pretty decent.
no 2 step for me. in fact im planning on slipping the clutch and nailing it through second as i care more about trap than et (mostly from a street racing standpoint but traction breaks things too... lol)
hehehe, that's what I did to avoid breaking barts... run it up to about 3k, then let her slip, when I'd do that with the turbo it'd make so much damn boost fast cuz the engine was still under load but then the tires would go up in smoke as I progressively loaded the engine more with the clutch. There's a fine line on traction and boost, trying to control it with the clutch and throttle at the same time makes it a little tough, not like an NA car. =)
Had 4.10's (28" tire) when I ran an M6, even did it with my TH400 (which sucks by the way). I now run a 3.50 gear in my 9"(as recommended by my converter builder Lenny) , its a match made in heaven and works great. The weight of your car comes in to play a lot too, if my car wasn't such a pig I'm sure I wouldn't be running a 3.50, I might be closer to a 3.08. My point is that I wouldn't go with too numerically low of a gear, keep getting some feedback on this thread & research,IMHO.
