Heads cam results?
Heads cam results?
Well i installed ls6 cnc ported heads and the ms3 (237 242 .603 .609 113lsa) and i put down 401 rwhp threw my 9 inch... so i went to the track tongiht and ran the best of 12.4 @ 114. All bolt ons and before the 9inch i went 12.8 @ 110. I no i can improve on my et but only gaining 4 mph from a H/C is this normal? i was hopeign to go 118-120mph. i hope this is the right place to post this and thanks for any helo you can give me. Also i am thorwin a p0106 code which is the map sensore code could this be hurtign me? thanks again
Originally Posted by 35th SS
check for vacuum leak around the intake area front and back.if not you have low vac.@idle.raise idle just a bit.good luck
on the 110 pass was at 11am in oct. i dotn remember the weather... last ngihts passes was dry and about 75* out got cooler as the night went on.... my best timeslip of the night was
60' 1.800
330 5.23
1/8 8.0
Mph 89.65
1000 10.4
1/4 12.407
Mph 113.95
then later on i went 12.6 @ 114
i dotn no what to do now but i sure thought i would be traping up near 120
60' 1.800
330 5.23
1/8 8.0
Mph 89.65
1000 10.4
1/4 12.407
Mph 113.95
Originally Posted by JNorris
I think a lot of your problem is weather related. I would think that weather in Oct in NJ would be much better for racing than weather in June.
Is your car full weight?
John
John
Originally Posted by 35thls1ss19
and he was traping 118 then hole night. Woudl that 15-20 hp diff make that much of a dif in trap speed?
How high are you shifting with the ms3?
however, if he put down 401rwhp, that car isn't going to trap 118-120 at his weight. i would expect maybe 116 at best, but 400rwhp is 400rwhp, it will propel the car at the same speed, whether it is through a 9" or a 10 bolt.
do you have a dynograph we can see, 35thls1? perhaps after we know where you're shifting we can help..
also, the weather would make a difference, but it took 94* temps and 99% humidity to knock my car down 2 mph in the 1/4. over a 75* and 35% humidity comparison...and i'm still on the stock tune.
Moderator
yes its full weight... the only othe rthign i dont understand is there was another guy there with a ws6 and afr 205's and fm13... he put donw 430 threw a 10 bolt. i put donw 401 threw a 9inch and he was traping 118 then hole night. Woudl that 15-20 hp diff make that much of a dif in trap speed?
I think so especially if the other guy is keeping his engine in the power band more through out the 1/4 mile.
John
Ur A/F could use some tweaking IMHO. Add some fuel down low and in the midrange, this will improve your TQ. Your definatley rich up top, you could pick up some hp by leaning it out some. Your 12.5 from 4500ish to 7k.
With this said it's not gonna improve your trap by 6 mph though. Your results seem similar to my buddys cammed car. Dynos well, 430/408, but doesn't perform down the 1320. He ran a best of 12.73@115, 2.1 60ft. This was with a TSP Torquer II.
For comparison I am running 12.5s@111-112, on 1.9-2.0 60fts with only exhaust, lid, and my own ported TB.
